Removes one or all of the redundant remote IP addresses from a mirror instance.
| mirror_name | Mirror instance name. |
| to | Selects mirroring to another location. |
| remote-ip | Send mirrored packets to specified destination IP address using L2 GRE encapsulation. |
| delete | Delete all or one remote IP addresses from a mirror instance. |
| all | Delete all remote IP addresses from a disabled mirror instance. |
| remote_ip_address | Delete the specified existing remote IP address from a mirror instance. |
| vr | Specifies a virtual router. |
| vr_name | Specifies the name of the virtual router to which this command applies. If a name is not specified, the current CLI context is used. |
If a virtual router is not specified, the current CLI context is used.
To delete all or the last remaining remote IP address, you must disable the mirror first (disable mirror [mirror_name | all]).
The following example removes the remote IP address "1.1.3.3" from the mirror instance "m1":
# configure mirror m1 to remote-ip delete 1.1.3.3
This command was first available in ExtremeXOS 30.4.
